Online: B0nes
head shake 2011 48 sportster
  • forty eight
    forty eight
    hey there all....i recenly purchased a 2011 48 sportster, and im trying to come to grips with some handling issues i have...the other night i took it for a ride and wouldnt you guess it pisses down.so with only 60ks on the clock i took it easy cruising in the left hand lane, and hit a section where they had repaird a section of pot holes... it had left a bit of a spoon effect through the section,as i hit the section the bike breaks into head shake and let me tell you i was worrried....ive ridden throu head shake before and know backing off doesnt help.so rolled on the throttle and tighten grips a little and came throu ok....any one had this expeirence or have some ideas to share please feel free to comment.....im 6ft 1  65kilos the bike has 16 inch tyres front and rear......
  • als1200
    als1200
    well done to hang on.  At least you knew to give her a bit more.
    i too havent had that happen on mine but the same as cookster just a bit of wallowing around some lumpy bends at speed.
    our roads are shit up here all the time.
  • Oldman
    Oldman
    They come fitted with a fork brace .
  • forty eight
    forty eight
    thanks for the reply...i also ride a wr426f2 dirt bike with all the trimmings, and the rule was your not off till your handle bar hits the dirt.(so i think i was hanging on)but will keep in mind.....as for the experience its sought off like the steering goes from left steering lock to right steering lock and back 20 times in about 100 meters.....if in doubt throttle out..
  • r0880
    r0880
     Check your tyre pressure as well.
  • forty eight
    forty eight
    thank for all the great information guys its been very helpfull....now correct me if im wrong!! a tankslapper is when  the ass end is overstreering due to heavy throttle use, then u back off and it gets traction and slambs u in to the tank.....as on my old r6 when u where exiting a corner and the back is driffting out then it suddenly hooks up.now thats a tank slapper..head shake normally is when you say power shift from first to second and the front bars start going from left lock to right lock very quickly.anyway peter stevens picked up the bike and said there was bearing movement so all 48 owners make sure you get it checked.rode to dayelsford and back yesterday and it was a big improvement..
  • aussiesport
    aussiesport
    dont talk about tank slap friggin shit ....had the oldgirl ( electra glide ultra ) fully loaded heading for albany we just pulled out of a servo about 3/4 the way across the nulla and got up to 90 kliks and fuck me the bars start dancing like a hooker on crack "shit me self stupid "the misses was like wtf ??!!!!! got thru it and pulled up checked out the front end and fucks me the front wheel bearings had collapsed !?? worth checkin ya bearings !!
  • forty eight
    forty eight
    well maybe its me,or my chicken stick arms but ive lost confidence in my 48.so peter stevens have agreed to take the bike back and let me upgrade to a 2011 xr1200x ..so i went to peter stevens and test rode the xr1200x and i was really impressed.allmost like a jap harley and please dont take any offence to that statement, just with the fully adjustable suspension it really handles great.loves to rev and the brakes are fantastic.,13.3 litre tank now your talking.now im just waiting for delivery.
  • SJ
    SJ
    Whatever suits. I definately wouldn't think most people are buying 48's for handling and brake performance (a lot replace shocks and spring at least). Im sure most want the look of a fat front tyre and small tank.
    If its agile performance, handling and braking you want, thats what the XR's were built for yeah?
    SJ
  • Inspiration2
    Inspiration2
    Gidday, first post on this nice forum. Had the same problem on my 04 883C and after excluding the head bearings, fork alignment, tyres, wheel bearings, wheel alignment etc, finally tried dropping the yokes on the stanchions 5-6mm. That cured the problem immediately and in 5 years it's never returned.
    The logic is simple. The weight distribution on the Sporty is biassed about 2/3s rear and 1/3 on the front. The stock bike rides like an outboard engined boat with the engine angled too far back, i.e. Sporties surf the road with a naturally light front end. Those few mm's shift more weight over the front end, give you slightly heavier steering ( a bit like having a friction steering damper) and prevent shimmying in the front end. Let me know how you go. Rex
