Online: Hesh, speedzter
WHAT ABOUT WARANTY
  • jocky
    jocky
    hi guys , coming up to 4000k on my bike ''2010 wide glide'' and want to fill all three holes with new oil. my question is waranty ,... will i effect it in any way, or should i just wait until my 2 year warranty is up and just get it serviced by the dealer every 8000k. honesty is appriciated,    jocky
  • kensim
    kensim
    if the oil meets the correct standard no problem,dealers will use syn 3 all holes if u ask,but in warranty period should be done by licenced mechanic just cover your self if something goes wrong.
  • jocky
    jocky
    its just that if i do the service at 4000 then take it to the dealer for the 8000, do you think they would be any the wiser? all i am doing is trying to cut some costs out as all of you blokes know only to well. then after the 2yrs is up iwould be doing it all the time.do you think thats afair thing.....jocky
  • Aunty X
    Aunty X
    Yep.
