Tire type and pressure.
  • yelladawg
    yelladawg
    Gidday all. I have a 09 FXDC. Running ohlins suspension front and rear. (huge improvement) I have always put on Harley branded Dunlops as tires wear. Done 30000klm onto 4th back second front. Question my pressure is 30 psi front and 36psi rear for one up. Two up i go 34psi front and 40psi rear. Are these pressures right? Also is there a better tire thinking maybe Metzlers next time any ideas. Oh yeah ride in new zealand things a bit twisty at times so need all I can get. Ian FXDC.
  • yelladawg
    yelladawg
    Thanks.the ohlins where pre set from the factory and have changed them about inch either way.Put them back to factory setting seems best.oh yeah thanks dave and other no namer.
