ANYONE RUNNING A TBAR ON A CUSTOM 08 OR LATER?
  • Midnite
    Midnite
    Has anyone done this?
    1. If so what did you go with - 6" 8" or 10" risers.
    2. Did you need to change the brake, throttle, clutch cables - or was it a simple bolt on job?
    Could you pls attach some pics or  a link for viewing?
    Help would greatly be appreciated.
    midnite
  • r0880
    r0880
     You haven't mentioned the speedo, what do you plan to do with that?  The riser on a custom makes changing bars more involved if you plan to do something that won't allow ithe original riser be used - such as T bars.
    Cables will depend on how high you go, its already 6 up 2 back plus whatever factory bars are.
  • Midnite
    Midnite
    Your right, thats why i am seeking others who have done this, and how  they have mounted the speedo to gather ideas on what ill do. .... If i cant get around it, ill use pull back risers with a drag bar and top plate. to get the t-bar look.
  • Midnite
    Midnite
    That would be great Gabby if you could!! - keen to see your pics
    cheers midnite
