How to fit risers on CVO Fatboy and keep tacho
  • Taffymarsden
    Taffymarsden
     I ordered 4" risers but once they were fitted by the dealer they said they couldn't fit the tacho so they left it off. The only other option offered was a very crappy look angle bracket to hold the tacho on. I made myself unpopular by asking them to put it back the way it was. (Actually they were pretty good about it and didn't charge anything). Their suggestion is a set of customised bars but they are expensive, especially with internal wiring needed, and I like the existing ones which are similar to wide beach bars but just a bit low for me. I'm just slouching a bit so even an extra inch would do at a pinch.
    I did get them to tilt the bars up a bit but that has pushed them a bit further away and made them worse.
    Any ideas for lifting the bars a bit that looks good but don't cost a fortune?
  • Daggs
    Daggs
    Just an Idea...
    fit some spacers and longer bolts under you standard risers.
    I made up some 3" long stainless steel ones once that worked a treat.
    Same OD as the bottom of your risers, 1/2" clearance hole up the guts and whatever length you want.
    Go to specalized bolt shop for the Grade 8 bolts you need.
    One piece risers that match your top clamp would be better though.
    you can buy riser extensions custom chrome sell them i brought a few sets not long ago for me tbars  tay come in 1 inch and 1 1/2  ,for 1 inch and 1 1/4  bars .
  • WozzA
    WozzA
     Have a look at the ZODIAC risers part # Z241144..4.5"PULL BACK in CHROME
        #Z241587...   4.5"Pullback in BLACK
                                                             or      #Z241164...   4.5" Straight chrome
      http://www.zodiac.nl/en/catalog/bbook38/14.pdf          section 14 page 025...
    Your Tac should mount the same as now...  just extend the wires from under the tank.
  • evilsim
    evilsim
    Taffy ... difficult to find a riser to fit and keep the CVO bars. Extentions and longer Grade 8 bolts are the go.
    I've lifted mine 1/2" to gain clearance because of my 3" tank lift.
  • Daggs
    Daggs
    Yr right Taffy, straight risers will bring the bars back a bit as well as up but curved risers will bring them back more of course
