Screaming Eagle tuner
  • cruser
    cruser
     Sorry to ask a question that has probably been done to death. I got myself a 2010 Ultra Limited mid way through the year, it was fitted with a Screaming Eagle EFI race tuner kit??  I have the box that is used to load the tune, the part number on it is 320995097. Is anyone able to tell me the part number of the cable and software that is required to enable me to play with the tune. or is there another part on the bike that will tell me the part number of the race tuner, and if so where would I find that. I am off to the states next week and want to pick up what I require while I am there.
    Being my first EFI bike and first Harley, I am a little less that familiar with things at the moment.
    Cheers,
    Cruser
  • wildchild
    wildchild
    Hey cruser, your might want to introduce your self in the Introduction area.
    Part number doesn't look right, could be;
    32109-08B (KIT-EFI SUPER TUNER,S.E. PRO HARLEY-DAVIDSON)
    or 41000008 (SCREAMIN’ EAGLE STREET LEGAL TUNER HARLEY-DAVIDSON) HD have change there part numbering system recently.
    Here is the info you need for 32109-08B
    32111-10 Software (this will do your bike)
    32111-11 Software (this is the latest 2011 version and I think the later EFI bikes require a different cable kit, not quite sure though).
    32184-08A Cable kit
    32101-10 Training disc (handy if your are new to EFI)
    Although I would recommend you check with a local dealer for correct part number to your VCI.
  • cruser
    cruser
     Cheers wildchild, appreciate the info.
    The part number I gave was for the box with the red button and light, that has a serial port and a USB type connector. I assume that this is the external loader unit.
    I had been looking on ebay and other areas for the cables, and as you said the number did not match up with the box I have, which was confusing me more than normal.
    Cruser
  • cruser
    cruser
     outstanding, thanks for the help!
    Cruser
