new 11 inch shocks
  • condor
    condor
    ok so i have just lowered my iron from the standard 13 inch shocks to 11 inch progressive suspension. this might sound weird but i have vance and hines shorts shots on it and after putting the 11 inch shocks on my exhaust is louder! am i going crazy? or is there a reason for this.. maybe sound bouncing of the road or maybe i have rocks in my head.. i dunno.
    feel free to give me shit or maybe a reason for this
  • Deadwood
    Deadwood
    Well if you did nothing with the front end then maybe the pipes are facing slightly more towards the ground making the sound louder?
  • SJ
    SJ
    Be the slap back midrange for sure. Should be more throaty when you ring it too.
    Same as hearing the ocean in a sea shell, thats distorted slap back of environmental noise amplified. Cupping hands to yell ect
    Cant wait to do the same.
  • Damon
    Damon
    Its just like when you ride past a concrete centre divider on the road and the exhaust gets louder due to reverberations.
  • multinut
    multinut
    maybe because your 2 inch's closer to them
  • 11bigm11
    11bigm11
    Have you had many issues with clearance when riding? Is it possible to take a pillion with 11" or will it scrub on every bump?
    Cheers Big M
  • Damon
    Damon
    Depends on how stiff the springs are, but 11-inches isn't too low. I'm at 10-inches and it doesn't scrub unless I put the missus on the back and then only on bigger bumps. I have air shocks of a touring model.
  • condor
    condor
    i have never had an issue with scrubbing, 11 inch is just fine. just make sure u have it on the right setting for ur weight and it will be ok. with a pillion i havnt tried it yet but i have a feeling there will be no problem, if there is just tighten the setting a couple of notches and it should be sweet
