Brawler seat compared to standard
    I was looking at something similar - no one here seems to have one :)
    I just got told, by someone that owns one, that the brawler seats are hard as a rock...
  • dav66h
    dav66h
    hey Skull
    ive had both ive got brawler now i had mustang before there is another topic in here called xl 1200 solo or something like that i left a message about what i thought i kept gettin a sore butt with the stocker but any other seat fixes that i was happy with the mustang but it didnt quite fit properly so i decided to go genuine i am happy with the brawler anyway its a chance to show of the girl cheers
    Photobucket" alt="" />Photobucket" alt="" />Photobucket" alt="" />Photobucket" alt="" />
  • outbak
    outbak
    If you have a 07/08 make sure u get the Mustang specifically for 07-08 models, it should fit fine (mine did anyway..). If you get the 04+ model you will have issues.
  • dav66h
    dav66h
    i did about 300km last weekend and no sore butt so iam happy the mounting bracket on the back of the brawler seat is a slot so you have a small bit of adjustment back and forth it also came with a quick release knob , with the standard seat i found i was getting a sore butt after about half an hour or so i hated it that much i sold it but every bodys different cheers
