48 front wheel on iron?
  • aussiesport
    aussiesport
    just a guess a bud but! the forks on a 48 are wider than on a iron/nightster so you would need wide glide trees and all the other crap for them ? but i cant see it costing $6k fork me a triple tree kits should on be about 1800/2000 and a wheel and tyre about the same ????? go figure do some research online bud :)
  • r0880
    r0880
     Was under impression wide glide had 41mm forks while forty eight has 39mm same as standard sportster?
    Anyway dealer obviously didn't want to do it.
    Not to worry, easy enough to have a front hub laced to a 40 spoke 16x3 rim.
    You will obviously need two wheels as iron alloy on rear and spoked 16" front will look shit, and need to confirm whether new triple trees and forks are needed.
    Next thing you'll see and want is a springer front, as on a crossbones.
    Buy a bike then see what you don't like.  Not going to save any money specing it up at the dealer.
  • TC883
    TC883
    Don't know about $5k to $6k, but the front ends are completely different between iron and 48. Forks are larger diameter on the 48, and the trees are mid glide, I think. Then the cost of the wheels, front and rear as pointed out already. New fork brace and front fender if you want it to be legal. Will also need to replace the headlight mount maybe? The 48 mounts to the bottom triple tree, the Iron to the top.
    It would be better to buy a 48 and keep the resale value etc if you really love the large front wheel. Remember, with the 48 you also get a 1200, forward controls and the smaller seat. I looked at both the 48 and the Iron. Went with the iron because it has more of what I want - mid controls, denim paint, narrow front wheel and I  prefer the look of the Iron. Lucky for me it was also cheaper! Either way, Iron or 48, they are great bikes and a heap of fun.
  • one_oak
    one_oak
     yeah you would be much better saving up for the extra to get the 48 if you really want it.
    To give you an idea of putting the 48 front end on a nightster its about $2500. Not sure if the iron would be different.
  • aussiesport
    aussiesport
    sorry r0880 i ment to say triple tree kits for the sporty they are 35mm /39mm depending on fork dia !. and if ya guna go wide tyre front go wide glide width ?! why go mid glide !! i thort we all bought harleys so we could fuck with them !!!!
