Online: B1ack, Hilly
installing a PC USB III
  • lapua
    lapua
    Hi guys I have spent hours searching the world forums for pics of a PC 3 installed on a soft tail/night train !
    I heard it is a bastard of a job too do so if anyone can share some light on the matter that would be very welcomed.
    lapua
  • sophtayl
    sophtayl
    Lapua, we have fitted a few. It can be a bit of a pain the first time, then a little less once you have done it. Why are you thinking PC3?
    regards
    M
  • Bobtail
    Bobtail
    I got a softail standard and the PC111 sits flat on the battery and the wires etc tucked around it with no probs, can't see there being too much dif with a nighttrain. The thing is not much bigger than a cigy pack.
    Bt
  • sophtayl
    sophtayl
    Hi BobT,
    We install them above the alarm as putting them between the battery and the seat is asking for trouble. A little bit more frigging around, but better for the long term
    regards
    m
  • lapua
    lapua
    I am thinking PC 3 because it seems to me the way to go without going over the top for a stage one but if feel you can add some more light I welcome it. I am new at this and open to new ideas that are correct for my bike.
    please post ahead mate
    lapua
  • sophtayl
    sophtayl
    Hi Lapua.
    we went from PC3 to the FuelShot Gen III after we trialled and played with them. Check out the threads in the "workshop" on the FuelShot. there is some direct feedback from other who are using them also. We were so impressed we put our name to them. You can also find out more at www.bigjoechoppers.com.au
    Feel free to email me if you have any questions.
    Mick
