Poor setup/suspension?
  • eyeball
    eyeball
    Todays ride on my Wide Glide, I noticed going around bends the bike "wallow's" at speed, is it  "just the way it is" or barely sufficient suspension? Im no expert on suspension setup so with such a heavy bike its all a bit of a learning curve. Its totally stock at the moment.
    A: rear shocks
    B: forks
    C: True-Track
    D: All of the Above
    when you don't know the answer you always pick C.... but seeing it is a Dyna you can always try D
  • WAGlide
    WAGlide
    Check your spokes on the rear. I had a evo wideglide & had to same symptoms as you & it was spokes. This is why the factory factory specify checking your spokes every 16,000 kms
