Fornales something missing- could be AIR!
  • BURTO
    BURTO
     What sort of pressure do ya run in those softail shocks? out of interest.
  • BURTO
    BURTO
    BBB Airshock Pump
    BBB Airshock Pump
    Special Features
      Precision 1.5": analog gauge encased with housing for better protection.
      External swivel hose for easy engagement.
      Lightweight, corrosion-resistant aluminum alloy barrel with nickel-plated brass parts.
      Slip-free ergonomic handle.
      Fine-tuning pressure bleeder valve for precise delivery.
      Specially designed for 400 PSI / 30 bar suspension shock. Maximum pressure: 400 PSI / 30 bar.
      2-stage non-leakage valve release system.
    This is the pump I use for my Fournales (dyna type shockies) and have had no problems with it after 2 years. I only pump up to around 15bar max but it is rated up to 30bar. Only just high enuff for your setup I guess but at $80, a lot cheaper than the Fournales product.
    Bought mine from Cecil Walker bicycle shop in Melbourne. Can buy online!
    Burto.
  • als1200
    als1200
    i brought a similar pump (low volume high pressure) for my shocks. works a treat.  local bike shop....about $70.00.  they use them for the mountain bikes for adjusting fork pressure.  Nice and small too.
  • lucky
    lucky
    gidday baloffski , i ride a 07 heritage , was thinking of fornales, are they as good as i've heard ,or just a bit of hype . cheers lucky.
