Tyre help
  • slip
    slip
    I need a new rear tyre for the Fatbob am going for the Metz 880 just need some feedback on weather a Metz rear Dunlop front combo would work or do i need to change both
          Thanks
    A lot of people run different Tyres front/rear with no drama's, but a matched set will probably work better.
    If your worried, just try it. If you dont like it fit a new front.
  • PigironBob
    PigironBob
    They will work, I ran that combo in my Fatbob when I had it, the Metz got only half the milage of the dunlops though.
