Kuryakyn Premium-ISO-Grips
    i have them ,i have had them for about 4mths great grip less vibration.the rubber inserts are soft  and the throttle boss is good on long rides ,i have there pegs and stirps   had them for 2 years  when thay where out  i will replace them with the same  and you can buy the rubbers separate if you need to .
  • CRASHER
    CRASHER
    i have a set too...had them on my fatty for a while they been sittin in the draw for 2 years...i prefer the standard oem rubber grips with my gloves...
    Crasher
  • V2Evo96
    V2Evo96
    I wouldn't use anything else on the BargeGlide-- I put throttle bosses on both sides as 'wrist rests". LIke perthhog I have the highway pegs with stirrups. I get 3 different leg positions with those.
  • AJ56
    AJ56
    great grips... I used to get pins and needles in my hands on rides. Put these on and no more...
  • LordViykor
    LordViykor
    Thanks for the replies, I'll have to place an order for a set.
  • blueystar
    blueystar
    just put a set on the finger burner and they do look a lot better than stock
    do a test run tomorrow and see how they feel
  • LordViykor
    LordViykor
    Placed an order for a set this morning.
