• johno01
    johno01
    Hi to all
    Hope ur all doing well
    i have a 08 sotail custom with v&h radius 2into2, a/f and tts tuner...want to change my cams for more low down power as most of my riding is two up with my mrs. what can you you all suggest???? cheers and take care johno
  • berms
    berms
    welcome to the forum.
    There are many great cams to choose from for great low end TQ..... Andrews 48H, TW-5-6....
  • FXDF08
    FXDF08
    Got a 2008 FXDF, hi-flow air filter, SERT, V&H double barrel staggered and SE204 cams.  The 204s are all about midrange.  Pull good from low, with dyno showing 100ft/lbs tq from just below 3000rpm and then stays there.  What more could you ask for from a stock 96? Apparently plenty of other good cams out there, but I recommend the 204s for two-up riding if you want to stay with HD engine parts (I did).
  • 2005 FLSTFI
    2005 FLSTFI
    I would think the SE 204 would be spot on to match what you already have on that bike
  • houli
    houli
    Seriously Johno, get a comfier seat to make your mrs happy and all your worries will disapear,unless she wants to be a passenger on a drag racer leave your cams alone the stocker is good enough in my opinion, but then again i ride a 1970 glide.
  • johno01
    johno01
    Thanks guys for all ur help and advise....appreciate it
  • johno01
    johno01
    Thanks for ur advise....By the way i have found all ur posts regarding tts tuner to be spot on and extremely helpful.....Thanks again appreciate it very much
