Brake/tail light connecter
  • AJ56
    AJ56
    ring the dealer and order one either male or female. When I connected my tow hitch I ordered the AMP connector from the dealer and they cost $8.00 with the pins. You need a special clamp to put the pins on though.If you only need a 4 place they would be cheaper as mine was an 8 Place connector
