Hi all, Had a great ride over the weekend however due to the vibrations of the shovel, I tend to blow a lot of flasher globs. I have picked up 4 LED replacements however due to the low resistance it will not work with the original the Flasher relay. I have a LED flasher relay however using the exiting wriring it will not flash just lights up the led's. Question to the group is there a set way to install this kind of upgrade? Regards, Troy
