99 sportster shock length?
  • Dicey
    Dicey
    I just ordered some Ikons for my 99 883 custom. I measured them on the bike and they were 11.5 inch but the guy at Ikon said they are 12" for that year model. I suspect the ones on the bike have lost 1/2 inch over the years plus adding a bit of weight of the bike since I measured with the shocks on it. Anyone know for usre the correct length and will it matter eitherway since its only 1/2 inch? thanks
  • kingchops
    kingchops
    I think 11.75 was stock for that year, so with the weight added 11.5 on the bike sounds right.  Half an inch won't be noticable much.
  • Dicey
    Dicey
    cheers ill go with the 12 as suggested by Ikon its probably not noticable as you say and more is better than less I reckon.
