Kuryakyn Informer LED Fuel and Batter Guage
  • AJ56
    AJ56
    Ok fitted this today along with the flush mount fuel cap.  Pretty easy in the end.  Although if you follow thier directions regarding the wiring to the speedo the wiring is permanent and then you will have problems removing the tank.  I ended up putting is a sealed connection between the wire to the speedo and the guage.  Then I can take off the tank without problems.  The hassle  is callibrating the guage, it took me about 10 go's to finally get it done.  The directions are pretty strict regarding covering the daylight sensor. 3 Seconds exactly.  I had a bit of a search and a lot of people had the same problem,  I tried 2-2.5 sec and got it right the first time....Although the directions don't say you can calibrate the guage as many times as you want....
    Overall pretty happy with the look and overall finish that it gives.  $139.00 US form M&M...
    my 2cents worth
  • BIGMARTY
    BIGMARTY
    YEP GREAT PRODUCT.
    JUST FITTED ONE 2 WEEKS AGO TO MY 94 FXDWG. VERY HAPPY WITH IT AND EASY TO INSTALL.
    $119.00 + POSTAGE ON EBAY
  • AJ56
    AJ56
  • tallmac1959
    tallmac1959
    NICE! - food for thought
  • AJ56
    AJ56
    That'd be right...... Bastads waited
  • Rans
    Rans
    Looks sweet mate..
    Rans
  • rowie
    rowie
    Another question. What is the blin fitted too. Been told they dont fit 09 heritage.
  • AJ56
    AJ56
    That was for the set, delivered from M&M. They both replace the original caps. If you go to the Kuryakyn web site you can download the instructions. Also lists models that it will fit to.
  • BIGMARTY
    BIGMARTY
    THIS IS MY EFFORT
    FXDWG 1994
    THANKS AJ56 FOR THREAD
  • Trendy
    Trendy
    I have the same setup with both caps and the instructions say to wait till near empty before calibrating to enable a personal "reserve" as when you calibrate it thinks you do it at empty. I haven't done it yet I'm still working down the fuel level, I can see myself on the freeway running out gas in a day or 2 though lol.
    Thanks for the post AJ didn't know you can re-calibrate it, nice tip as the instructions say you only have 2mins to calibrate after you turn the ignition on so it's a bit deceiving........and ya tank looks the goods too mate, nice !
