Dyna Ignition switch
  • Cubicinches
    Cubicinches
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=12&postid=106994&view=topic
    J just completed this mod on mt Street Bob. It has always annoyed me, having the key switch for lots of reasons. I did this mod it's as easy as. I picked up a soft tail switch the trickiest bits were
    The hole shouldbe 48 mm
    extend the wires from the key switch by 5 or 6 inches and you can use the switch connecter rather than spade fittings.
    Great mod and very cheap
