Licks Solo Bag
  • r0880
    r0880
     They rave about them on US sites, are they available locally?  I'd imagine freight from US would hurt.
  • Damon
    Damon
    Yeah, I have one on my Iron. The bag itself is very good quality and comes in pretty handy for small stuff like hats and cameras. It is only held on with velcro straps but I've had mine on for six months and it has never moved at all. Fills a pretty neat void on the opposite side to the exhaust which is why they're so popular. Without the bag this part of the pov looking swing arm looks like an eyesore.
  • old faithful
    old faithful
    The only thing that I didn't like was the mounting system (leather/velcro straps)
    So I used a velcro strap (around the swing arm) on the bottom rear, on the top rear I used the leather strap around the down member (tube) of the frame and on the front I made a angled bracket which is fixed between the pillion peg mount and the frame  and is attached (bolted) to the back of the bag with an aluminium backing plate inside the bag.
    I've done over 20k since I've fitted it on the bike with about 3kg of tools, a puncture repair and spare gloves in it and it's as rock solid as the day I fitted it.
    I reckon their good value!!
  • fizball
    fizball
    I gotst one too. Like Damon says, very good quality, small (enough room for a jacket, goggles and a 9mm)  and fills an ugly void.
    Not trying to take away from licks, but if you're a bit low on the spondoolies, La Rosa in the states also make em. They look similar but about $20 cheaper.
  • Clement
    Clement
    Hi,
    Does anyone know if there is a group buy going on for the solo licks bag?
    Damon, is you bike on a bike stand?
    Cheers,
    Clem
  • Paul.C
    Paul.C
    Just ordered 1 today.
    They say they are very busy and the wait is about 2 weeks for shipping.
  • Damon
    Damon
    Oh, should have mentioned. Lick's are HOPELESSLY SLOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOW to send products. Expect eight weeks....
  • outbak
    outbak
    I got a tan one for sale if anyone wants to make an offer - as new. Used for a week and then i decided i didnt want it after all. Can take a photo if anyone is interested
  • Clement
    Clement
    Hi All,
    Did anyone pay the extra $25 bucks to jump the que?
    Clem
  • Paul.C
    Paul.C
    Mine turned up this morning.
    Ordered on the 18th Jan and got it 1st Feb.
    The quality looks very good, now time to fit it
  • mistajace
    mistajace
     could you fit a leather jacket in it or is it too small?
  • mistajace
    mistajace
     ok. cause i like them but that is all id use it for... thanks
  • Clement
    Clement
    Hey Scouser,
    Love the 48...you've done a brilliant job.
    Do you think the Licks is worth the money? and any chance of some estimated dimension?
    Cheers,
    Clem
  • Cruisin
    Cruisin
    et.com/albums/h440/Robbo48s/hog112.jpg[/IMG]
    Got these throw overs from the states http://www.xl1200.com for $312 us delivered
    & i am more than happy with them.
  • Cruisin
    Cruisin
    Obviously i havnt worked out fuckbucket yet
  • Cruisin
    Cruisin
  • Cruisin
    Cruisin
