Online: beaglebasher
Chrome Cover Trims?
  • Nancy
    Nancy
    Hi all
    I've got a mark on my aluminium primary cover (think it maybe a petrol stain)does anyone know if there is anything i can use to remove it?If i can't remove it i was thinking of getting chrome cover trims (covers not the real thing) does anyone have these covers on there bike if so do they look good?
    Thanks
    Nancy
    I have the covers on my bike and their great , fit very well and you carn't tell
  • outbak
    outbak
    mine are covers and I am happy with them...
  • kingchops
    kingchops
    Nancy,
    The covers look good I've seen them on a couple of bikes. If you want to get stains out of your aluminium covers use Mothers Power Metal - Aluminium. You should be able to find it at an auto store. It's great stuff makes the polished covers almost as shiny as chrome after polishing (pitty they don't stay that way for ever). I used it to get water marks off mine they came right off with minimal effort. I used heaps of other cleaners before and they made no difference.
