Online: Stuart, softfat
REAR FENDER BOLT HOLES???
  • 07deluxxxe
    07deluxxxe
    18 years ago
    hey guy's , arsehold the pillion seat on the softy , and got those 3 holes in the rear guard , went and got stainless button head cap screws and washers to cover the holes but it still looks shithouse , any suggestions???
    is it simply weld em up n re-paint or is there a less painless solution?
  • kingchops
    kingchops
    18 years ago
    This may be over simplifying things but there's a hole in my fender used to fit the dual seat and it has a black plastic cap in it. Covers the hole quite well. You could probably get some of those from a dealer?
  • kensim
    kensim
    18 years ago
    they look better those little black caps.
  • 07deluxxxe
    07deluxxxe
    18 years ago
    think that might be for number plate relocation stix , im talking pillion and luggage rack holes
