Difference in Colours
  • FAT TONY
    FAT TONY
    Hi Guys
    does anyone know what the difference is ( if any )
    between the Orange Screamin Eagle Pro Super Tuner & the Black Screamin Eagle Pro Super Tuner
    both have same part no. 32109-08B
    thanks
    Fat Tony
  • Rans
    Rans
    Hey BT,
    The orange one is the newer updated one with a few other features, there is plenty of info on the net, just google the part numbers one at a time and you will get all the info you require.  The part numbers are the same, except for the B on the end, so leave it off and that will find you the black one, add the B and you will find the orange one. Hope this helps mate.
    Rans
  • FAT TONY
    FAT TONY
    Thanks Rans
    very helpful info - wish the dudes on ebay knew what they were selling
    quoting part no + B and showing the black one
    better stick buying from Zanotti's
    thanks again
    FT
  • Rans
    Rans
    Hey mate,
    I got quoted around $380 plus postage from M&M, so that could be an option for you brother...
    Rans
