Online: John.R
Belt Drive Guard
  • Spidey
    Spidey
    Hi all,
    Just a quick one for some advice from the people that have done this to their bike. I am thinking of removing the belt guards off my fourty eight so it gets cleaned up a bit. The question I ask is, does it speed up the wear and tear of the belt. It is just what I have been told or was the guy bullshitting to me. If it does wear out quicker how long do think before the belt needs replacing?
    Cheers, Si
  • motor_head
    motor_head
    Spidey, all it takes is one small pebble to get in there and you have a broken belt.
    Iv'e been riding my bike for 4 years without one,,,,, Take it off,, By law you only need one if you have a passanger seat and rear pegs fitted
  • Daggs
    Daggs
    Broken belt pain to change and illegal, don't ask me how I know ....
  • Spidey
    Spidey
    Thanks for the ideas fellas, i am still thinking about doing it, i noticed i one guard underneath the swingarm, i might leave that one on and the one on top it is going to disappear. That is if they are two separate bits, I havent looked that close yet...
    Cheers, Si
    Leave the Lower on.... only only remove the top
  • Spidey
    Spidey
    Sensational stuff Walka, thanks for showing us that picture. its exactly what i was thinking... its getting done tomorrow..
    Cheers, Si
    Steamer it's got NOS on it too ,,,,,,,,, who cares
