starter motor
  • hellboundpig
    hellboundpig
     starter motor croaked lucky it started to get me home its on 07 softail fxt 103 ci thought it would last longer than it has.
  • Dyna1994
    Dyna1994
    mine is still the original with over 200k on the clock
  • hellboundpig
    hellboundpig
     Have to get the sucker out and see whats wrong with it mite have to buy one on fleebay if i cant repair it.
  • cruzees
    cruzees
    Done the basic tests m8 to see if its the actual starter?
    lead from battery to terminal on starter?
  • hellboundpig
    hellboundpig
     stater works but doesnt  engage ring gear all cable ok it will turn over if you hold the starter button.in untill it engages .
  • motor_head
    motor_head
    I had a similar problem, bad news is my memory is nearly non excistent, good news is i removed the primary cover and checked it out, from what i can remember there is a nut that holds the starters cog in place and another bit that holds the nut in place, ( was like a locking device ) . the problem with mine was the nut locking device thingy had decided to bend which let the nut to unscrew which loosened the cog on the starter shaft,  end result was, when i tried to start the bike the cog on the starter shaft didnt engage with the cog on the primary shaft which meant the motor didnt turn over, hope that helps.
    PS. my bike is alot older than your's so dont know if it all works in the same way.
  • V2Evo96
    V2Evo96
    Not much info to go on but:
    Pull the primary cover and check starter cog and jackshaft travel egagement, and of course look at the ring gear. Your looking for a bent or siezed jackshaft and or missing teeth on ring and shaft cog.
    If OK pull starter and take it to an workshop that rebuilds starters. Most bits are replaceable with off the shelf automotive bits available anywhere.
    do not buy new starter or take to dealer for repair....yet. I also note you have punched your 96" to 103"-- any other changes? Headwork, cams, etc. can work a starter hard....
    your comment "it will turn over if you hold the starter button.in untill it engages" makes me think low voltage at the starter solenoid but I'm guessing. Always start troubleshooting with the simple stuff first. JM2C
    Let us know how you go.
  • hellboundpig
    hellboundpig
     Had starter motor apart appears to have a buggerd starter shaft clutch  orderd parts and also a heavier duty starter motor and keep the stock one for a back up.
