48 Coil, Ignition and Tank Lift
  • BAKES
    BAKES
    Looks good
    But where is the horn relocated too
  • mistajace
    mistajace
    i will be surprised if the screw that holds the ignition barrel to the bracket doesnt sheer off. it happened on my custom bracket, so i drilled it out and put a bolt through....that fixed it good.
  • Harley_Dude
    Harley_Dude
    Looks great!
    I would be intrested in knowing what kit you bought, price and where from as well?
  • sjn25281
    sjn25281
    Does anyone know, can you do the wire tuck without the tank lift? I hate the plastic moulding but dont really want a high tank...
  • SIR883
    SIR883
    I dont know man, i not a fan of the tank lift on the 48's...
    I would keep the low slung look....and keep the tank down...thats how i would do it.
    just my opinion.
  • Spencer72
    Spencer72
    What size tank lift did you get?
  • zerocool
    zerocool
    looking good scouser
    i did the same with mine taped it up but didnt like it so cable tied everything to the top of the frame :)
  • RedNed
    RedNed
    My relocation ignition coil/switch on my sporty - just for interest sake.
    Coil cover from Debrix, some flat bar, bit of MIG work, some fancy plug leads and it matches (sort of) my S&S teardrop filter on the other side.
    No tank lift just some re-routing and taping with hi-temp 3M looming tape - didn't put any cabling between frame backbone and tank - causes insulation chaffing and problems further down the track.
    Chris
  • ConR
    ConR
    I know this was posted a while back, but wondering...how much range did you lose on the tank with the lift? i.e. 30kms less?
  • terroristone
    terroristone
    With my 1 1/2 lift I maybe lost 10-20ks
    T1
  • ConR
    ConR
    That's on the 3.3 gallon tank though right? Wonder what it's like on the 2.2
  • ConR
    ConR
    Sweet! Thanks! My ass has healed up finally, and I'm almost done with the purchase of a 48!
