Got stuck into the tank over the last couple of days, stripped it back to bare metal using paint stripper, then laid down a primer coat and a base black coat. Put the flames on today, was a bit worried they wouldn't turn out as I've never done it before but I'm pretty happy with the way they look. I'll thin out the flames with some red pin stiping. Am looking at using some pin stripe tape around the edges before I put the clear coat on. Here's a few pics.
KC, great job mate...the sporty is looking the goods...well done brother
paint stripper worked well on the tank
