Online: Stuart, Hilly
tripple tree change to wide
  • timmey
    timmey
    Hey guys
                      Looking at buying a dyna , but i feel the front end needs a little  'meaness'  added to it   , so i though of getting wider tripple trees for it  [just like wide glide]
    Except for the new trees and some spacers for the front wheel and gaurd ...anyother problems may come up ? Also do they all use the same forks too ?
        thank you timmey
    depends what year dyna ? a mate changed he,s l 98 lowrider over to 41mm front end useing ,same wheel ,make disc spacers,(twin disc)longer bolts for discs,gaurd spacers ultima /midwest forks 2inch over,axel and tripple trees ,but had to get the steering lock notch machined in the stem shaft and get the top tripple tree machined and drilled an taped to suit the head light fair bit of work but it looked great afterwoods
  • Daggs
    Daggs
    yeah, need to know what year and as stated, whats needed is trees, axle, axle spacers, disc spacer, fender spacers and longer bolts for disc and fender... thats about it
  • DaveP
    DaveP
    And while your at it replace the bearings
