Footpeg circlip removal tool
  • Dan
    Dan
    just popped mine of with a screw driver...
  • monarofan
    monarofan
    yep, 2 small flat blade screwdrivers for me
  • IK
    IK
    And if you bend one and go to supercheap for a replacement well they don't fit :(
  • SoftailSteve
    SoftailSteve
     I got mine from Supercheap Auto, it was about 8 dollars i think.
  • RumDeluxe
    RumDeluxe
    OK
    - am I missing something here, or has someone got a better solution for these stupid little circlip things.
    Have lost two so far having pinged to undetectable parts of a badly lite and rubbish filled shed.
    THERE has got to be a better way - or thing.
    With all the reverse engineering elsewhere on the scooter is this really the best way of hold footpegs on - surely NOT !!
  • Rocky2010
    Rocky2010
    You can buy chrome nuts & bolts from Harley but they look to ugly and chunky. Circlip is a much cleaner  look
  • Rxes
    Rxes
     I filed down a standard pair of circlip pliers and when I remove them, I put a peice of masking tape over half of the clip to catch the little fuckers when they fly off. Have also used Blu Tac.
  • RumDeluxe
    RumDeluxe
    Thanks for the quick feedback guys.
    Rocky & Ando - looks like the only viable alternative is chrome bolts and nuts - might give that a go in the long term.
    Short term I will buy a pair of pliers and file them down to suit the job at hand.
    Cheers to Macka71, steamer and choppersmad for the hints.
    Rxes - good tip with the masking tape or blu tac - will try that out after I got some better clips and pliers.
