Online: B0nes
Cruise control problem
  • Rick1310
    Rick1310
    Hi all
    I put a cruise control on the bike a couple of weeks ago went down the south coast today cruise worked well going down. But coming home no go, I have checked the fuse & everything is still connected all lights are coming on the tacho & the switch but thats it, any ideas.
    I will be call the dealer where I bought it from tomorrow hopefully to get some help.
    Thanks Rick
  • Rick1310
    Rick1310
    I even tried to do the cable reset but could get it to work the logo would go green like it says in the book. ButI will check the clutch cable tonight & thanks
  • Rick1310
    Rick1310
    All the cables look alright I will play more tomorrow morning. At least you type on ur Iphone on here as mine the keyboard will not come up for me.
  • Rick1310
    Rick1310
    Just got back from a dealer & they could get the system to diagnose but they would pull the bike apart but could take all day & may not get finished. That was a 1/2 hr charge, so now I waiting on some news from Harley Heaven where I bought the part from. But after the ride on the second I will pull the bike apart & check the wiring conections.
    Thanks
  • Rick1310
    Rick1310
    Sorry mate it would not regiseter on there machine the switch would work to start the diagnostic, they would have to start pulling the bike apart & checking the wires, cables & what ever else. Harley Heaven is going to get back to me next week with what I have to do, take it off the bike & send it back under warranty.
    But my email is street.glide.07@hotmail.com & thanks for the help.
  • Rick1310
    Rick1310
    Hi Hogbagger
    You wouldn't believe it but I thought I would try it on my way home to on the run & the bloody thing is working again not missing a beat. What was the manuel you got that info from so I can look into getting one.
  • Rick1310
    Rick1310
    Thanks for all you help
  • Rick1310
    Rick1310
    Just like to give an update.
    After trying a few things with hogbaggers help nothing seemed to work & Sys's couldn't get anything on there system. Us less they pulled the bike apart & looking at all teh wires. So I took it home played around & found nothing, took it off & re-installed & still nothing. I spoke with Harley Heaven & they said to return the unit to Harley Heaven & they would send me another one, which they did.I have installeded the replacement kit & so far so good.
