Fat Bob tyre pressure
    The fitting has it's own valve in it, and when screwed in, it opens the tyre valve. So yes, they work for checking and inflating.
  • Hesh
    Hesh
     Have one of these right angle jobbies as well and they work great. You just have to remember when you pump it up, put a little extra in, as when you start to unscrew the valve, it lets a bit of air out.
    I usually go about 1 psi more than recommended and after the valve is removed, it's the correct pressure. Works a treat every time
  • Hesh
    Hesh
    I bought mine from my dealer in Brisbane. Didn't cost much at all from memory, less than 10 bux I think.
  • FTBOB
    FTBOB
    I got a right angle adaptor from MCAS (on their website under road tire accesories, www.mcas.com.au) $10, and also a small pressure guage, digital
  • Taffymarsden
    Taffymarsden
     I had a non-HD (forgive me) bike where the gap between the rear brake and the valve was so close you couldn't even use the angled adaptor without loosening the valve and moving it sideways. Seriously stupid. How can someone have the engineering skills to design an entire motorcycle and not figure out that you have to put air in the tyres?
  • xcited
    xcited
    I have found the digital ones at woolies caltex fit on fine. At home I use a flexible tyre inflator from ARB running off the compressor in my ute.
  • JimD
    JimD
     scored one of these from Rolling thunder - bloody handy (part # 42300009)
  • Normthe1
    Normthe1
    Fuck me, I have never even looked at mine and its about to click over 5000k's... Off to the shed...
  • shingles
    shingles
    I bought my gauge from snap on tools flexible shaft and has rotation at head of point of fitment  so hose can go full 360 at head cost 50buks is a quality product I only buy lifetime  lasting stuff ,also u can release air if to much ,pressure should be 36psi two pump up I have a pushbike high pressure pump which has two types of valve applications ,hose is flexible over foot long that's how I inflate my tyres this pump will even pump car tyres ,I mainly use pump on my high pressure pushbike tyres which is only way to inflate as they run 120psi garage inflator wont do this pumps cost 50- 60 online stand up push down type as used by cyclists for racing type bikes but pump has 3 uses 4 me
    as you can see there are a few styles to fit.
    I have a ac-5 for home use and a ac-7 that i use at work, Ive had them for 20+ years and cant remember from where i got em.
    Google schrader valve chucks in images and you will see them. Top end suppliers should be able to get for you.
    I then use a pressure guage with the ac-5 end on it as it fits all schrader valves with limited space. (like the back wheel of mt ultra).
    Hope this helps
