Online: Stuart, Hilly
Cleaning the black part of the motor
  • twincam88b
    twincam88b
    Okay, question for people with the black motor. I usually was my bike with good quality cleaner and chamois off. I use Macguires polish for the paint work, and varoius products for the chrome. But how do you get the black on the cylinders and other black parts looking clean and new? Is there any spray product that can be used at the end of the clean up to make the black sections look new again???
  • 2005 FLSTFI
    2005 FLSTFI
    There was a thread on this topic while ago.
    Some people use inox others use that S100 stuff ( expensive though)
  • FXRfreak
    FXRfreak
    Yeah the S100 is good stuff, there is a better one out of the states called "Pig Snot" if ya can find it and that is supposed to be the best.  I use the S100 and it does a great job, it is expensive, but it lasts a long time, each application will last many washes, and if you use it sparingly and as directed a can will last a long time.. Hope that helps.
  • Train
    Train
    I use the $2 tyre shine tip that I got from the other thread. Works a treat
  • blueystar
    blueystar
    black boot polish dose the job
  • twincam88b
    twincam88b
    Thanks for the tips people....I will try and find the other thread. I probably missed it as I haven't been on here much lately.
  • wilso
    wilso
    engine brightener - spray from the stealers
  • russ4570
    russ4570
    WD40 - Smells great when it burns off too.
    RT
  • HAMM3Rsix
    HAMM3Rsix
    what is this "washing your bike you speak of" LOL
  • silverbullet03
    silverbullet03
    I have always used MR SHEEN on 3 of my harleys always brings it shiney and smells nice too.........
  • silverbullet03
    silverbullet03
    Sorry forgot to say to get the motor warm and then spray it evaps quickly so no rubbing.
  • Lastrain
    Lastrain
    Yep ... Mr Sheen, was recommended by the stealer and works great ... will try doing on a warm engine next time?
