Flat Battery
  • travelling2008
    travelling2008
    Hi Peoples,I have been a little croook and went to start my bike and BAM,a flat battery.
    So my question is,if i disconect the battery to charge it up,will i have to reset my bike computer with all that password and stuff once i reconect it?
    Any assistance would be apreciated.
  • Brett
    Brett
    Mate ,I don't think you will lose the settings when you disconnect the battery,I took the earth off to connect my fuelshot and everything worked ok when re-connected,I think it reverts back to the default settings.Read your manual re battery removal if you have an alarm fitted, or wear earmuffs.
  • travelling2008
    travelling2008
    Hey guys many thanks for the input,i have read the manual and it really doesn't say anything,so i guess i will just have to go out and see what happens.As my bike has the alarm and all that computer stuff,it freaks me out if i am doing the right thing.Its all the computer stuff that is stressing me out,otherwise i would just rip the battery out and charge it up.
    Will try later when feeling better,but again thanks for the input.
  • Taffymarsden
    Taffymarsden
     08 there is a back-up battery that protects the settings when the main battery is disconnected.
