Online: beaglebasher, B0nes, Stuart
are all evo 1340 heads the same ? will thay all fit 1340 evo
  • dazza69a
    dazza69a
    are all evo 1340 heads the same ? will thay all year 1340 evo motors heads and boars fit each other?
    darren.
  • V2Evo96
    V2Evo96
    The Clymer 1984-1999 EVO service manual does not mention any differences in the actual heads, however the head bolt torque spec is different between the 1984 FXST and 1985-on heads. PLease check with a tech that knows EVOs inside and out, as Clymer manuals have been known to be in error.
    If you need the head bolt torque spec send me a PM.
  • dazza69a
    dazza69a
    cool thanks for the info i got get me a workshop manual.
  • dazza69a
    dazza69a
    thanks dave you all you guys are great help with lots good info love this forum.
  • V2Evo96
    V2Evo96
    Thanks Dave,
    Based on your input I re-checked the Clymers Manual I have and have found the following info related to head studs. Not trying to pick you up, just stating from the manual:
    1984-early 1985 used female at the top male stud bottom.
    1985-1987 used male both ends no collar (flange) at head end.
    1988 - on used male both ends WITH a collar (flange) at the top.
    No reference to head breather in this 1984-99 manual that I can find, plenty of info on crankcase breathers. No impact to the actual heads either way.
    cheers,
    V2
