Abnormal wear?
  • eyeball
    eyeball
    Just after opinions on my front tyre, its done a tad over 3k km's and is the stock tyre fitted from HD.
    All around the front tyre are these "scallop" type of grooves or cuts which are all uniform, which look quite abnormal to me.
    Theyre not a part of the tread pattern.
    I know these "wear and tear" items arent usually a part of the warranty but in my opinion, this shouldnt be happening.
    Your thoughts/opinions are appreciated.
    Peter
  • eyeball
    eyeball
    cheers for the input guys, ill give Frasers a bell today.
  • eyeball
    eyeball
    GT502F, 80/90/21
  • eyeball
    eyeball
    Not sure what you couldnt resist there Uncle Ho?
    Anyway, gave them a call and emailed the pics to them, ended up going for a ride up there this arvo.
    Expecting all sorts of crap to be thrown my way, and a lot of explaining/running around, but I couldnt fault
    Frasers service.
    The manager (think its Rob?) came out, had a look and said theyd change the tyre there and then, and he'd sort
    it out with HD.
    Couldnt ask for better service really.
    Double thumbs up for Frasers Perth
