Online: Stuart, Hilly
softail rear ends the same ?
  • dazza69a
    dazza69a
     is a 1996 softail rear the same size as a 2007? i want to put a 2007 wheel in my 1996 heatage softail.
    can any one help with this info.
    also will all softail seats fit other softails  etc?
    darren.
  • dazza69a
    dazza69a
    ahh so i cant put the 200 size wheel in my 1996 arse end ?  and i cant change the arse end to a 2007  one then fit the bigger wheel?  bugger.   how wide can i go with my heratige arse end its got a 130 in it now.
    darren.
  • Sparra
    Sparra
    You can buy wide arse kits to go on earlier softails...I think they start at around the 2g's mark without the wheel and tire...It has been discussed in here in length so if you do a search you should find plenty of info....i have a 2004 Fatboy seat on my 1995 FXSTC and it fits fine....I did try a 2008 standard seat and although it fitted it just didn't look right....
  • dazza69a
    dazza69a
    thanks for the info sparra.
  • dazza69a
    dazza69a
    might  try a 180 on mine sounds like it will fit without any mods.
    are all 1340 evo heads the same will thay fit on any 1340 evo  duzz any one know?
  • dazza69a
    dazza69a
    ahh ok cool.
    i might just look into  getting a wheel that will fit mine as it is  a centerline or somthing.
    yer the fender is guna just fit the 130 wide wheel under it if i put a load on the back.
    its got a 16/130 in frount and back  i was looking to make my heratage look more like a fatboy.
  • dazza69a
    dazza69a
    just get the angle grinder and mig welder out  should sort it out ok..lol.    just kidding..
    think im just guna try find some centerlines or some cast wheels that look good that fut under my standard  ass end.
  • dazza69a
    dazza69a
    will doo
    just got find some wheels now.
  • dazza69a
    dazza69a
    looks good what thay charge for that?
  • monarofan
    monarofan
    you'll get a 150 under the back no worries
