Online: beaglebasher
Can fit a 200mm tire on FXDB no mods??
  • SuperGlide
    SuperGlide
    Heard that you can whack a 200 tire on standard FXDB (mine is FXDBSE but same thing i"m sure) which is 185 from the factory.
    Anyone confirm this??? There is no tire rub inside teh guards etc / no bolts need to be shaved or anything??
  • ezzyd2009
    ezzyd2009
     i am in the  process of doing my 2013 fxdb. i will let you know how it goes.
