fuel chip
  • beerman
    beerman
    still huntin for things on recently purchased 2007 superglide, this time its the fuel chip. ive had a mans look
  • CRASHER
    CRASHER
    ok...well take this slowly...when u bought you bike what did the stealer tell you?..
    or if it was private sale..what did the previous owner tell u he had done to the bike?
    when we have this information it will be easier to help you..
    generally if there is a piggyback system it will be under the seat or in the battery box connected to your ecm
    if it has been SERT'd or TTS'd u wont find it because its been loaded into your ecm..there fore on purchase you should
    have been given a tuning dongle about the size of a small cigarette pack..hope this helps
    Crasher
