I want to look after my 08 Night Rod?
  • tjvrod
    tjvrod
    Hi just got my08 1250cc Night rod special and it needs some tender lovin, where do I take it now?
     It feels like it needs a good tune a lube may even may even need plugs
    So do I take it to the local fraser motorcycles at Concord?
    Can any of my new HD family members recomend a place to go?
    Is their someone around Bankstown area?
    Thanks for your help in advance.
  • tjvrod
    tjvrod
    58 lookers and not one word of advise
  • imoo6170
    imoo6170
    I have used S&R Pro unit 5/6 121 Coreen ave Penrith NSW 2750 phone (02) 4732 2203 for dyno tuning my 07 VRSCD - Power Commander, Staintune pipe, K&N Filter Topless. Found them to be very good.
    If you want a straight plug / oil change and don't want to do it yourself, try P&L Performance Cycles, Unit 2/200 Toongabbie Road, Toongabbie, NSW, 2146 (02) 9636 9955.
  • tjvrod
    tjvrod
    Thanks
  • tjvrod
    tjvrod
    Spoke to Jamie today,
    Thanks
  • Springer_13
    Springer_13
    Mate if you want the plugs and oil changed, Im happy to do it for ya.
    I live over at Holsworthy.
    If you want a full tune then try Sy's, Mild to Wild, LA Cycles, S&R Pro......
  • tjvrod
    tjvrod
    Fat Tony.
    All good now Took it to Penrith SnR Pro, Jamie fixed it up....
    Thanks
