Cleaning DriRider Gear
  • Bikers Mum
    Bikers Mum
    I need help to clean my foster sons DriRider Pants (they stink soooooooo bad).  He has lost the care instructions and there are none on the inside of the pants. He must sweat a lot!!! Anyway if anyone can help I would really appreciate some advice.
  • cactus60
    cactus60
    burn them ? ok ok.. i have no idea.
  • blueystar
    blueystar
    take them to a dry cleaner
  • 308bever
    308bever
    get `em to ride thru a carwash a few times (((-; then put their riding gear on and get them to do it again! (((-:
  • Taffymarsden
    Taffymarsden
     Just so you get at least ONE sensible answer out of this entertaining bunch, I'll have a look at the label on mine and let you know. My wife won't allow them inside (!) but the smell is exhaust fumes.
  • Snowie
    Snowie
    As a female, who does mountains of washing every week, I would stick them in the washing machine with plenty of washing powder and some fabric softener (I only use fabric softener because it makes my washing smell nice) and put them on a delicate cycle ... it works wonders for my boys' school blazers, which are marked, 'dry clean only'!
  • beagle
    beagle
    Remove all padding etc, put in a warm machine wash, short gentle cycle. Do not spin. Remove, put over an outside chair, hose any suds out, repeat if necessary and let air dry. I could add about sniffing the crotch to see if it smells better, but I won't.
  • Taffymarsden
    Taffymarsden
     Here are the instructions that came with mine - sorry this took so long:
    1. If wet, air dry on hanger
    2. do not store unless dry
    3.dry away from direct heat
    4. do not dry clean or iron
    5. hand wash in luke-warm water and detergent
    6. do not wash in bleach or solvent
    7. do not machine wash or spin dry
    8. mobile phone should be stored in inside pocket (huh? why do they bother telling us this?)
    9. important to adjust velcro fasteners properly so the velcro does not abrade the shell of the jacket
  • blueystar
    blueystar
    bikers mum any feed back are they clean yet or do they still stink
  • WozzA
    WozzA
    Poor bloody kid has probably been trying to get them like that for ages
  • beagle
    beagle
    Ya know you can turn em inside out for an extra couple of days wear. And always leave them on the top layer of ya bag with a big skid mark facing up, for when ya go thru customs. Usually scares em off.....
  • Annie888
    Annie888
    I wash our Dririder wet weather jackets every year after winter -- don't see why the pants would be any different. Remove any armour, then into the washing machine. Hang in the shade to dry    THEN    buy a can of Scotchguard and spray them real good !! [drown the things]  This waterproof's them again. Make sure they are dry before storing away
  • Annie888
    Annie888
    ..................and Robo, are you practising to be Superman?  If'n your Y fronts need waterproofing from the rain they gotta be on the outside!!
    Or else you ride around with your "playground" open
  • jacks
    jacks
    Smelly pants is good...shows he pushes to the limit...a badge of honor like..
