Upgrade brakes on '99 custom
  • Dicey
    Dicey
    Just bought a 1999 883 custom and looking to upgrade the front brake system. Can anyone recommend something good that will fit without too much hassle? Brembo? WHat are some good brands out there? Does anything just bolt on?
    Thanks.
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=1&tpage=1&view=topic&postid=256477#257123
  • Dicey
    Dicey
    cheers thanks
