Bike miss fires through air cleaner
  • Nomad62
    Nomad62
    Guys,
            Fitted a set of V&H big radius pipes, Fuelpak and screaming Eagle pod filter to my 2010 Street Bob. I have noticed on a couple of ocassions it will not start on first attempt, and on second attempt will miss fire through the air cleaner....or at least appears to come from there.
    Has anyone else experienced this??
    Any ideas on settings on my fuelpak that may cause/correct  this ??
    Nomad
  • skin10
    skin10
    have been having same prob on 2010 wide glide vance and hines big radius thunder max s&e heavy breather went to ride it this morning same prob but now it wont idle i am taking to dealer today let you know what they say
  • the_mongrel
    the_mongrel
    I get an occasional miss fire through the air kit, bit very rare. I think it is because I let go of the starter to quick.
  • Nomad62
    Nomad62
    Thanks skin, be interested to see what thet say.
    Nomad
  • Nomad62
    Nomad62
    Hi Mongrel,
                    Yeah i know what you mean, i have a habit of doing the same thing with the starter.
    Only noticed the miss fire since i put the fuelpak on though, so i have e mail one of the techs at Vance and Hine to see what they say.
    Will post the response.
    Cheers Nomad
  • AJ56
    AJ56
    I had that same thing after installing cams. Ended up being to lean on the start. Only ever done it in the morning. Scotty sorted it out for me in no time...He used the TTS... which I am going to get in the new year...
  • skin10
    skin10
    got my bike back today going realy well they said they reset the map on the thunder max and they said that it didnt pop miss and now idles fine
