Online: Stuart, Hilly
fixing oil leak with silicon?
    No not normal !
    A small amount in a few spots just to hold the rubber seal in place would be acceptable.
    That or some heavy grease would have worked.
  • houli
    houli
    O ring grease for o rings, silicon is excellent for gutters, shower screens etc not engines / gearboxes it has a habit of going where you do not want it to go eg oil galleries and bearings.
  • Daggs
    Daggs
    loctite 515 flange sealant is what i would use (if anything) in this senario.
    It was the cover right? not the plug?
    not a biggie really, the main thing is the o ring could have been damaged so they should have fitted a new one and made sure they didn't pinch it again
  • Dyna1994
    Dyna1994
    i use hi temp silicone sealer , just a smear and leak is gone
