Springer front end
  • HAMM3Rsix
    HAMM3Rsix
    Just a quick question how fast can you ride with a springer front end
    I have heard not much over 140 km
    Is there a issue at high speeds with them or are the new one capable of handling this regularly
  • Filthy
    Filthy
    Modern springer front ends are far more stable at any speed than the standard Harley front end.
    Philthy
  • CRASHER
    CRASHER
    OK i got the flame and shame suit on...i have run the STD HD front end out to 190 tapped out on the 09 XBones and would push it harder if it could go harder...seems fine untill you start to corner thats when the trouble starts..i boiled it bdown to the ape hangers,giving me the tank slapper feeling..only a very few have seen how bad it was pushing it at 160-180 in the sweepers, Fucken scary shit man...now after changing the bars and putting upgraded shockies front and rear...this thing handles better than my fatboy...im stoked
    Crasher
  • HAMM3Rsix
    HAMM3Rsix
    Thanks crasher I am looking at buying a after market springer front end good to hear you can ride that fast I sometimes run around the 180 mark when riding with my brother so I was nt sure they could handle these speeds plus any bike can be a bit rough at that speed
    Are you saying is ok now the shocks have been changed to after market on the hd springer front end???
    Thanks.
  • CRASHER
    CRASHER
    H6...it is definitely 100% Better and safer to ride with the after market shocks...i have chosen Fournales Air Spring front and rear shockies for the CrossBones and still in the break in stages before i can start playing with the pressures to find the right combination for street use, and road use....i give them a big fugggin thumbs up so have a set goin on the Fatty too....I'm sure there is a cheaper better product on the market...i just bought at the right time when the dollar was good and off shore...
    Crasher
