Is this the truth????
  • Big H
    Big H
    I ordered flush mount fuel caps (p/n 75027-08B) and the US dealer sent me (p/n 75027-08). I questioned the US dealer on the item and they say that the 75027-08 should be the same and there will be no issue with fitment or function.
    Can anyone else confirm this???
    Thanks
  • the_mongrel
    the_mongrel
    Hey Big H! I had a similar issue where the part they sent me was the right part number (or so it seemed) but the fuel cap did not fit. All I had to do though was take a dremel to the plastic bit of the fuel cap and it went on OK.
    I can't find the part number in the catalogue without the (b) and the catalogue states this...
    75027-08B
    Gloss Black
    Fits '08-later Softail® models (except FXCW and FXCWC) and '08-later Road King® models
    So I reckon it will be fine.
