Willy g grips install
  • lapua
    lapua
    Hi guys got new wiily g gear full dress kit for my 08 Night train ,question on installing the new grips any good pre starting method ,all ideas welcomed.
    remove current grips and install new ones.
    lapua
  • GREG
    GREG
    Get something like a padle pop stick to slide under the stock grips. Work it down and around to break the glue, a bit of WD40 helps as well.
    Wouldnt have a sniper background would ya lapua?
  • lapua
    lapua
    ex ADF
  • cheechman
    cheechman
    compressed air using airgun under the grip and pull.
  • jacks
    jacks
    Mine came off with a lot of grunting and swearing,  the WD40 helped too........Good luck the effort is worth it,,(the swearing too!!!)...j
