stroker kit twin cam
  • hrcruisin
    hrcruisin
    My son's 03 twincam has way 2 much end play in the crank, needs a new crank etc, I can get a s+s 106 stroker kit with pistons and 45 mikuni for about 2 grand from the states,I got a quote for the labour and was told about $2800!!  Seems a bit steep.
    It already has a 95 big bore kit in it so no need for a rebore.Can anyone tell me if $2800 is a fair price for the labour??
    He reckons about 30 hours,I thought about 20 would be about it
    hrcruisin
  • issues2
    issues2
    Just had my 01 twin cam rebuilt recently for the same reason.
    While it's apart I recommend you go the Timken bearing upgrade in the cases,New oil pump (heart of the engine),gear drive cams with upgraded support plate & have the new crankshaft trued,balanced & welded.
    I think the 45mm mikuni will be too big as I've been led to believe they work best on motors 120 & over.
    I run a 42mm on 116 S&S with no probs.
  • hrcruisin
    hrcruisin
    thanks
    Guess he'll have to see if there's a cheaper way to do it instaed of the stroker.Does anyone know of somne who does bottom end rebuilds at a reasonable price?
