Online: Soapbox2627
Clean white wall tyres
  • SoftailSteve
    SoftailSteve
     Just purchased a set of whitewalls and the white band is grubby, tryed cleaning it with ajax, didnt seem to clean up very well, anybody out there got any ideas???
  • Filthy
    Filthy
     Steel wool soap pads & warm water.
  • SoftailSteve
    SoftailSteve
     tryed Steel wool soap pads,then degreaser and finished with wax and grease remover and its looking very nice .thanks for your help
  • cactus60
    cactus60
    2 dollar degreaser, spray on and wipe with green scour pad, then hose off. best results i have had
  • SoftailSteve
    SoftailSteve
     thanks every one for there help . steve
  • Maxiboy
    Maxiboy
    Fuck! If you do that too often you won't have whitewalls for long, Use Jiff with a SPONGE in one direction. They go fluro white, abasive pads will lead to tears if you do it every week.
  • Smokey61
    Smokey61
    A capful of Handy Andy in half a bucket of warm water. Use a scrubbing brush. Should come up like new.
  • la0055
    la0055
    Brand New Whitewalls with blue coating and a lot of grime gathered over time in warehouse I suspect.
    Tried it all ..... Jex, Handy Andy and Finish with a scrubbing brush, WD-40. All work with varying degrees of success, but none got them white enough for me.
    Then I tried Jif on a damp cloth and BINGO !!!!!!!!! Perfect.
  • wazza430
    wazza430
    I use hand cleaner and a bit of elbow grease. Works a treat.
  • Hooters
    Hooters
    Ive found a great product at mitre 10, I think it was called majic white or something. Its a white sponge which you just slice a small piece from and then give your white walls a rub with it and some water. No chemicals or hard scrubbing. If I hadnt used it myself I wouldnt believe it could be that easy. I use it on all sorts of stuff now, it really is that good.
  • Hound_Dog
    Hound_Dog
    I just use thinners. Been doing it for 10 years. Never had an issue and the WW's come up beautifully.
  • Mr.Mow
    Mr.Mow
    I tried all that stuff with the new BF Goodrich tyres on my jeep to get that blue shit of the white lettering, hours of scrubbing and sweating.. then tried the Harley whitewall spray on and wipe off after 2 mins stuff.. genius, it works great. Did all 5 tyres in 15 mins.
  • graz
    graz
    Jiff. Been using it for years on 4wd tyres and white walls on two bikes. Never fails.
  • Spook
    Spook
    Or just buy black wall tyres?....
  • noctm
    noctm
    had to clean my white walls this weekend as i got a new rear put on, which had the blue film protection on there and the front was pretty dirty too.
    used jif and a cloth, rinsing as i went, and it was really easy done. have heard gumption will also do the trick nice and easy.
  • noctm
    noctm
    double posted for some reason
