starter relays
  • evoshovel
    evoshovel
    Im tiding up my wiring and I have seen diagrams with starter relays fitted.What does it do and what is the advantage of  wiring one in?
    My bike runs and the battery charges but the wiring is a mess.
  • evoshovel
    evoshovel
    thanks Ray
  • als1200
    als1200
    gday,  sounds like fun.  are you having problems at the moment?
  • evoshovel
    evoshovel
    Ive had a couple of problems in the past I have replaced almost every electrical bit but the wiring is still a dogs breakfast with wires going nowhere and others change colour from one end to the other,
  • The Don
    The Don
    Hi
    I posted this for another member sometime ago, you might find it useful.
    Also, there's wiring diagrams at     drop.io/1979FXS      just paste on your browser without the www.
    Cheers, Cris.
     BASIC HARLEY WIRING DIAGRAM
    Wiring your Harley.
    The first thing to do is to find the wiring diagram that best suits your bike.
    1- Disconnect your Battery and remove. Earth wire first!! Remove you existing wire loom, if any. (You may be able to use some of the outer covering later.)
    2- I’m assuming all your electrical components are in place, eg: Headlight, Horn.
    3- Using a minimum 14 gauge strand Automotive type wires, select your colours for each component and route the wires connecting components. Work with only one wire at a time, and leave an extra 4 inches of length per side as insurance.
    Tag each wire end and write WHERE IT GOES. Tape the wires to the frame so you have a rough wiring loom.
    4-For the Battery and Starter Motor use at least 10 gauge wire.
    5- Once you have all the wires laid out, route them so they will not be in danger of rubbing or dangling. You can now make a wiring loom and touch each wire end to the component it’s attached to. Without removing the tags, cut each wire down so you have 1 inch over the required length. Remove the loom.
    6- You are now ready to affix terminals to your loom. Do it on a clean flat surface, make sure the soldering iron can be used safely. If you have kids this is a time you don’t want them around.
    7- Avoid using spade or horseshoe type connectors, over time they have a tendency to open up or spread. Use eye type terminals that fit the studs or terminals on the components. These will tighten up nicely using star washers.
    Don’t hook up wires without connectors, it’s a disaster waiting to happen.
    8- Crimp or solder terminals well, I prefer to do both. Do not over crimp, excessive force will end up with a bad connection. Always use the appropriate size terminals for the wire gauge being used.
    9- Avoid splicing wires in the middle of a circuit if you can run one wire instead.
    10- You can now install your wiring loom, use tie wraps every 6 inches or so and route the loom away from contact with heat. You should be able to install it so it’s pretty much hidden from view.
    11- After you finish and before connecting the battery, Double Check Every Connection! Better to be safe than sorry.
    12- Connect the battery, positive first and test every circuit.
  • evoshovel
    evoshovel
    Thanks The Don, the diagram is just what Im after as Im using points. Ive got other diagrams but they are too confusing and I have trouble following them.
